ROP Fetch /OpenGL - Frame not finishing, yet output is there
   1936   2   1
Hi there,
I'm creating jpg flipbook sequences with the ROP Fetch fetching an OpenGL ROP.
For some reason, sometimes it gets stuck on a single frame.
The frame is already created, as I can open it in an image viewer, but TOPs doesn't see it.
It just keeps going, thinking the frame isn't ready, stalling the tasks down-stream.
When I right-click on the task and click ‘Cook Task’, it instantly finishes.
Since this is something inside an HDA, I'd like to not have to manually cook any straggler frames.
I haven't found anything on this so far, so any tips are most welcome.
I'm on Linux Ubuntu, H18.0.416.
Eckhart
- A little nonsense now and then, is relished by the wisest men.
When that issue happens, is there still a process running for the job that's hanging? It'll show as a hython process running the rop.py job script in your process monitor.
I'll have a look once it happens again and let you know.
When I changed some settings such as the frame range, it didn't happen anymore.
