Hi everyone
Im trying to export a USD sequence to Unreal engine and I am just failing to
I have tried flattening the stage, sperataing the layers etc... nothing works in Unreal
It only works in Unreal when I import a single frame
Does anyone know how to do this
Thank you
Houdini Unreal Engine USD export animation sequence
3915 6 1-
- henrythejedi
- 61 posts
- 8127 posts
- henrythejedi
- 61 posts
jsmack
take out the frame number expression in the file name.
Hi jsmack
Thasnk ou for your thought
I did remove the $F in the filename during my tests and sometimes it produces 1 big file, which Unreal simply doesnt load
When I import this same usd file without the $F in houdini using an import USD node, when I scrub through the timeline, the fll geometry doesnt show, its only when I turn on display bounding box on the USD import node that I can see something is happening and changing with the bounding box, but the full geometry does not show
- 8127 posts
henrythejedi
Import USD node? you mean the sublayer LOP? If it doesn't show up when read back into lops, there must be something funky with the scene.
- henrythejedi
- 61 posts
jsmackhenrythejedi
Hi jsmack
Is there any workflow on how to do this, the expprting of usd sequence to something like unreal engine
Most tutorials out there all focus on exporting a single frame
Thank you
- 8127 posts
By usd sequence, do you mean a usd that contains animation, or a sequence of usd files that each contain a single frame?
Usually you want the former since there's not really any way to use the latter without a usd stitch clips operation to merge it into a single file, or by using the convoluted usd operation to create value clips.
If you really want the latter though, the USD ROP needs "Flush data after each frame" enabled.
Neither of these options explain why your setup isn't reading back as expected when written as a single file. The screenshot shows a bunch of configure layers with file paths that don't contain frame numbers, so putting a per-frame token and writing out a sequence of frames from the rop might not work as expected. You'll get a file per frame from the top most layer, all layering in the same set of layers.
If possible post a scene file demonstrating the problem.
- henrythejedi
- 61 posts
jsmack
Hi jsmack
Thank you so much for your responses
I have attached the scene file here
Thank you
Edited by henrythejedi - 2021年4月24日 12:53:00
