KineFX Livelink rotations/scale wrong in UE4
   Views 2596   Replies 2   Subscribers 0
I was able to get the two programs to talk to each other but when the livelink is active the skeletal mesh shrinks down to 1/100th scale and some of the rotations are off. I tried correcting for it with an animation blueprint in UE4 but no luck getting it perfect.
Any help would be greatly appreciated, I could easily have missed a step somewhere but I've tried everything I can think of like transform nodes, units settings, reimporting at a larger scale, etc. but no luck.
Hi decksounds,
Sorry if this is a distraction to your issue.
Im having trouble getting Kinefx livelink working at all.
Im following the instructions found here:
https://www.sidefx.com/docs/unreal/_live_link.html [www.sidefx.com]
I downloaded HoudiniLiveLink-4.26-v1.0 from the git repo
After importing the file ue4_livelink.hda and attaching a sphere node to the input of ue4_livelink1
i see this error on the ue4_livelink1 node
Invalid source /obj/geo1/ue4_livelink1/computetransform1
Error: No transform attribute exists, unable to compute local transforms.
when I click on "startserver" button I get this python traceback error
Error running callback:
File "Sop/ue4_livelink/start_server", line 1, in <module>
File "Sop/ue4_livelink, PythonModule", line 75, in start_server
File "Sop/ue4_livelink, PythonModule", line 57, in outputPlaybarEvent
AttributeError: 'NoneType' object has no attribute 'pointFloatAttribValues'
Can you give me any clues as to what should be input to the ue4_livelink1 node to resolve the errors Im getting?
thanks
just for completion this error on the ue4_livelink1 node
was resolved thanks to a suggestion by bubblepins
insert a rigdoctor node right before the ue4_livelink node
