I've been having a hard time figure out how to work with volumes in Solaris, especially when it comes to rendering them via the Arnold Hydra plugin. I've figured out how to shade and render them for the normal Arnold IPR, but I can't get them to even show up in the Arnold Solaris viewport. Anyone have examples of the proper workflow for this?
As a side-note, I found other people with the issue on the Autodesk forums but they seem to think it's a Houdini or environment issue. However we're a shop with a pretty solid Houdini environment setup and are using 18.5 so I doubt that's it.
https://answers.arnoldrenderer.com/questions/25664/how-to-render-vdb-volumes-in-solaris.html [answers.arnoldrenderer.com]
How to render Pyro in Solaris with Arnold?
8352 9 3- NFX
- 183 posts
- schwungsau
- 31 posts
- NFX
- 183 posts
- AhmedHindy
- 136 posts
- Eche
- 42 posts
- mtucker
- 4524 posts
AhmedHindy
SOP Create and SOP Import dont work with volumes
Just wanted to clarify here... SOP Create and SOP Import do work with VDB and Houdini native volumes. At least they should. If you have a hip file demonstrating a case where they don't, please post it (either here or send an email to support@sidefx.com).
It's possible that they don't work in the viewport with Arnold, but they should be displaying properly with the Houdini GL and Karma renderers.
- AhmedHindy
- 136 posts
mtuckerAhmedHindy
sorry for the late reply, this SOP Import, Scene Import and all other methods work for rendering vdb in karma/ openGL, but Arnold (tested late versions of HtoA 6.2) doesnt work and will give you a blank viewport with zero errors.
only working method I know is the "Volumes" LOP to load the .vdb file sequence.
- NicTanghe
- 212 posts
There is a youtube video with a hipfile from someone that recreated the standard pyro shaders.
https://youtu.be/kskWKXdSK5s [youtu.be]
Edited by NicTanghe - 2023年1月4日 12:39:57
- levinwunder
- 3 posts
I finally got volumes working in Solaris with Arnold but now I have a new issue.
I am trying to render particles as volumes. In the regular rop context this works perfectly fine, after setting the step size > 0 in the geo container arnold settings. If I do the same in solaris with the rendergeometrysettings node it doesn't work however.
Does anyone know how or if this even works in solaris?
- mrcbersani
- 22 posts
