Crash after random time caused by whitewater
   1585   4   0
Whitewater simulation causes a random crash during mine simulation. It does not exceed ram, it just crashes after a random time.
I'm almost sure, that it happens on /obj/whitewater_import/set_density node.
I'm attaching the log, after few hours of trying to disable/enable OpenCL, Density control, and any other option I'm not sure what to do with it. Please let me know if any info is needed.
Water simulation without whitewater seems to work fine
My RAM is not exceeded, I had this problem earlier with white water simulation, but this time apparently that's not the case.
Regards
Edited by p4vv37 - 2021年7月11日 06:51:48
crash.improved_sim_5.pawel_3964_log.txt (8.6 KB)
crash.improved_sim_6.pawel_13237_log.txt (8.5 KB)
Ye olde signal 11 error. Aren't those related to hardware? Are you overclocking and monitoring your heat?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
No, I'm not, all is default,
I'll run memtest and some stress tests then
If you have a reliable crashy hip file send it to support. They like those.
Memtest and stress tests did not help, but deleting the
/home/pawel/houdini18.5
directory did, that was something connected to files in it. Possibly some custom otl? I'll contact support.
It works fine now. Thank you for replays anyway
