Hi.
I cannot find how to export to fbx some nodes with python. Is it possible to do in Houdini. I have Indie version.
I only found fbx importing through python: https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=16206&highlight=&sid=0e48aeb092269469b0504485d319a8ca [sidefx.com]
FBX export through python
12083 9 2- Pavel Geraskin
- 93 posts
- Enivob
- 2629 posts
Have you tried the saveToFile () method passing a filename with the .FBX extension?
node.geometry().saveToFile(file_name)
http://www.sidefx.com/docs/houdini14.0/hom/hou/Geometry#saveToFile [sidefx.com]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Pavel Geraskin
- 93 posts
Enivob
Thanks for the reply. I created a sphere object and tried this code:
hou.node('/obj/sphere_object1/sphere1').saveToFile('$HOME/Documents/Exchange/exchange.fbx')
But i got exception:
File “<console>”, line 1, in <module>
AttributeError: ‘SopNode’ object has no attribute ‘saveToFile’
- jkunz07
- 76 posts
- Pavel Geraskin
- 93 posts
jkunz07
Adding geometry() like:
hou.node('/obj/sphere_object1/sphere1').geometry().saveToFile('$HOME/Documents/Exchange/exchange.fbx')
should fix this
Thanks for the answer. The exporter cannot export to fbx. Only obj/dxf/lwo.
And I cannot export a scene with hierarchy to fbx with python. I'll write to SESI for a feature request.
- caesar
- 143 posts
- Pavel Geraskin
- 93 posts
- jparker
- 316 posts
You can always wrap the fbx node into a python script:
# create a temporary ROP node
fbx_rop = hou.node('/out').createNode('filmboxfbx')
# set the output path to whereever you want the file to go
fbx_rop.parm('sopoutput').set(“$TEMP/out.fbx”)
# Path to object hierarchy you want to export
obj_path = hou.node('/obj/geo1').path()
fbx_rop.parm('startnode').set(obj_path)
# Now just run the “render” method on the node, and delete the ROP
fbx_rop.render()
fbx_rop.destroy()
fbx_rop.render()
fbx_rop.destroy()
- fkkcloud
- 26 posts
I get error when I try to createNode() I am using Indie version btw.
The attempted operation failed.
File “hou.session”, line 6, in <module>
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.313/houdini/python2.7libs\houpythonportion.py”, line 541, in decorator
return func(*args, **kwargs)
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.313/houdini/python2.7libs\hou.py”, line 5374, in createNode
return _hou.Node_createNode(*args, **kwargs)
OperationFailed: The attempted operation failed.
This node cannot contain other nodes
- huozuyinshua
Enivob
http://www.sidefx.com/docs/houdini14.0/hom/hou/Geometry#saveToFile [www.sidefx.com]
Its worked for me , thanks
