Multi object output
   5394   8   1
I have problem with having desired number of outputs in Unity with hdalc files. When I am using use output nodes but it always adds one extra object.
Can anyone tell me what I am doing wrong?
Thank you in advance.
Edited by Gand - 2021年10月20日 20:19:38
Hi, I fixed an issue regarding duplicate geometry in Houdini 18.5.744. Can you try updating to that version using the daily builds and let me know if it works?
I'm also having this issue , but on the latest daily of Houdini 19.0.425
Im also on the updated unity houdini engine package from the same installation , only difference is that im not actually getting a second output with my version compared to Gand
I saw your commit here https://github.com/sideeffects/HoudiniEngineForUnity/commit/171f121da8d2064ac3b6711156bbc098d03b8179 [github.com]
Thanks for keeping the plugin up to date Anthony! hoping we can help figure out some bugs, im going to test this in 18.5.749
UPDATE: Confirmed not to be working in 18.5.749 either, Only getting one output
Edited by moferad - 2021年11月2日 22:57:14
Interesting, I might have found another problem, I noticed recooking is not actually updating the asset, and I have to forcefully "restart session" and recook again to see any change happen, not sure if this is related , this is happening on 18.5.749
added a video
Edited by moferad - 2021年11月2日 23:40:56
SessionBreaks_hq.mp4 (14.9 MB)
Hi, I have identified several issues regarding geometry outputs after the "output node" change. See https://www.sidefx.com/forum/topic/81539/ [www.sidefx.com] for more details. It should be fixed in 18.5.753/19.0.430.
Thanks @Anthonyt2
Ive grabbed latest and wiped my old plugins folder for the new package in 19.0.430 , unfortunately im still seeing a problem with the multioutput
The image below shows that it still is not outputting the second outputs, am I doing something wrong?
The second image shows that by setting split by groups I get both results out of my hda, although its odd because it needs to be set in the plugin settings , the "split geo by groups" toggle in the hda itself does not do anything
Hi, sorry, I implemented another bug fix for Houdini 19.0.433. Now, all outputs should be display (instead of just the first one) when using output nodes.
Edited by anthonyt2 - 2021年11月9日 14:51:04
Hi ! I am using the new option "Use output nodes" in my .hda wich works well. But when I bake it into a game object, I loose all my separate nodes, it result one game object. Is it possible to keep multiple output when I bake it ?
Thanks !
Edwin88
Thanks !
This looks like something we must have overlooked. I'll mark this as a RFE. For now, you can try just dragging the outputs out manually.
Edited by anthonyt2 - 2021年12月13日 10:54:01
