KineFX Skeleton viewer state not showing
   Views 3300   Replies 9   Subscribers 3
I'm wondering if anyone else is having this issue. I'm in H19.0.383 and I can't seem to get the Skeleton SOP's viewer state to show. I can get other nodes with viewer states to show (such as Draw Curve, Paint Attribute) but despite having the node selected and the Handle cursor active, I only see the toolbar for the previous node I had selected.
Anyone able to reproduce this issue? Thanks!
on my end, it happend when i had py2 packages installed (specifically aelib).. once removed.. everything was fine.
Oliver Hotz
Origami Digital
Author of ODTools for Houdini: https://origamidigital.com/cart/index.php?route=product/product&path=59_63&product_id=66 [origamidigital.com]
Also have this, RFE'ed last week(SESI #113420) and also retested in .428 on request of SideFX, still occurs.
Clean install, no packages except for Labs. Python 3.
oliver7
Thanks for that. I've submitted that on the beta but the guys at SESI couldn't reproduce the error on their side.
guilhermecasagrandi
oliver7
Same problem here with H19.0.383...
Remove aelib not solve the issue.
Not working for me too Hope it gets fixed.
believe it was fixed in a daily build
Oliver Hotz
Origami Digital
Still happening with Topo Transfer.
removed aelib package and it worked for the skeleton SOP.
bone capture biharmonic though is not displaying colors although it works because i can move the skin geo.
capture layer paint displays colors but throws this error :
"ERROR: C:/Users/User_/AppData/Local/Temp/houdini_temp/hfs18376-71.tmp (51): Hotkey symbol "h.pane.gview.state.sop.capturelayerpaint.select" not found"
Edited by papsphilip - 2022年2月21日 12:32:29
I was having similar problems with Renderman installed on 19.0.383. Went back and forth with both SideFX and Pixar. They said that supposedly it was fixed with the .455 update. I haven't had any problems since updating to .455 and beyond.
madebygeoff.com
