Houdini 19 doesn't load AT ALL on Ubuntu 21.10
   50591   120   17
Thank you. So I’m general these issues with karma rop and Houdini 19 not loading at all on Ubuntu 21.10 are caused by changes to libraries included in the build?
chrism
sudo apt install libopengl0 freeglut3 freeglut3-dev
Cool, now Karma is working in the viewport, I had to reassign materials but they are working
Edited by GCharb - 2021年11月5日 12:46:35
Screenshot from 2021-11-05 12-34-08.png (1.4 MB)
chrism
sudo apt-get install --reinstall libxcb-xinerama0
Wow... Running this really made a difference!!! Not a crash so far! Any other tricks and libraries to reinstall to make it more stable proactively?
I find that I have to run 'source houdini_setup' and 'export LD_PRELOAD="/lib/x86_64-linux-gnu/libc_malloc_debug.so.0"' from the command line every time I run 'houdini'. Even after it crashes every time.
TY!
GCharb
chrism
Yes, worked magic for me as well.
chrism
Apparently some users had luck installing some linux missing libraries:
Thanks Chris,
In my quest to get H19 Karma running I've checked the system requirements for Linux. Does it make sense to include them here: https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
Thanks again and happy weekend
I got 18.5 and 19 to start, but it's a bit of a roll of the dice. At least 50% of the time it will result in a crash. I'll post some of the crash reports tomorrow.
So, I have all the libs mentioned above installed on a fresh 21.10. as mention it does work, but it takes a few tries sometime to get houdini launched. Simply launching it from the terminal. I get various type of crash ranging from no message at all to this :
Traceback from 8222 ThreadId=0x7fd9553f7cc0
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
__sigaction <libc.so.6>
free (tcache.h:406)
_nv014glcore <libnvidia-glcore.so.460.91.03>
<libGLX_nvidia.so.0>
vk_icdNegotiateLoaderICDInterfaceVersion <libGLX_nvidia.so.0>
and this:
houdini-bin: pthread_mutex_lock.c:90: ___pthread_mutex_lock: Assertion `mutex->__data.__owner == 0' failed.
8576: (sent by pid 8576)
8513: Fatal error: Segmentation fault (sent by pid 908)
Traceback from 8576 ThreadId=0x7fd18c690cc0
pthread_kill <libc.so.6>
raise <libc.so.6>
abort <libc.so.6>
<libc.so.6>
__assert_fail <libc.so.6>
pthread_mutex_lock <libc.so.6>
je_tcache_bin_flush_small (mutex.h:77)
free (tcache.h:402)
Edited by lrntbrt - 2021年11月6日 18:33:58
19.0.430 daily build is no longer crashing for me like the production build. Redshift 3.0.59 works fine as well.
But 18.5 remains an issue, production or latest daily.
chrism
Using Pop_os 21.04, this fixed houdini 19.0.383 not showing anything in the sceneview and crashing when switching to a render engine such as karma in a solaris view.
I have the same issue but on Fedora 35.
None of suggested things hepled. Any idea?
Mirko Jankovic
What error are you getting?
munmap_chunk(): invalid pointer
Aborted (core dumped)
On .383
and with daily build 450
Segmentation fault (core dumped)
Any ideas?
Fedora 35 here
Run
Before you run Houdini from the command line.
You might still get segmentation fault after so just keep typing houdini and it should load on 2nd or 3rd attempt.
I’m actually quite disappointed that sidefx havent fixed this yet. Assuming there’s a good reason. Maybe complexity.
Still no luck:
ERROR: ld.so: object '/lib/x86_64-linux-gnu/libc_malloc_debug.so.0' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
Mirko Jankovic
Still no luck:
It might be that the libc_malloc_debug.so.0 file is located elsewhere on Fedora. I'd check check if it actually exits at that location. If it doesn't, try to search for it in your system.
Edited by kubo-von - 2021年11月26日 18:17:36
export LD_PRELOAD="/usr/lib64/libc_malloc_debug.so.0"
Found it's the location it preloads without error but now different error:
56935: Fatal error: Segmentation fault (sent by pid 1107311872)
Crash log saved to /tmp/houdini_temp/crash.cgoven_356935_log.txt
sh: line 1: xmessage: command not found
And in that log file:
Crash report from cgoven; Unknown App Version 19.0.383
Uptime 0 seconds
Sat Nov 27 07:38:10 2021
Caught signal 11
Traceback from 356935 ThreadId=0x7f4656ff9e00
__GI___sigaction <libc.so.6>
free <libjemalloc.so.1>
_nv014glcore <libnvidia-glcore.so.470.86>
I was getting the same error until I exported the correct path, now at least it started.
Edited by mzigaib - 2021年11月28日 10:38:06
What correct path? I still have same problem on fedora. although just tested on rocky linux and it works fine...
I just did like you described:
And it worked
ah I see. no luck here...
Actually I got a lot of fatal errors when I try to launch:
12441: Fatal error: Segmentation fault (sent by pid 1433951232)
This is what says that log:
Crash report from user; Unknown App Version 19.0.451
Uptime 0 seconds
Sun Nov 28 15:51:49 2021
Caught signal 11
Traceback from 12441 ThreadId=0x7ff2a9f16dc0
_nv014glcore <libnvidia-glcore.so.495.44>
But I type Houdini again until it works, weird but it works.
I am hoping that since Fedora 35 is relatively new some future updates can solve the problem?
Edited by mzigaib - 2021年11月28日 18:20:38
