Mikktspace Tangents in SOP context
   Views 2225   Replies 0   Subscribers 0
I have been attempting to build the node from this git project unsuccessfully:
https://github.com/teared/mikktspace-for-houdini [github.com]
Once I get through setting the paths to find Houdini and VS libraries I get the following error:
Build started...
1>------ Build started: Project: SOP_ComputeTangents, Configuration: Release x64 ------
1>Calculator.c
1>mikktspace.c
1>SOP_ComputeTangents.c
1>Generating Code...
1>LINK : fatal error LNK1104: cannot open file 'libhboost_thread-vc142-mt-x64-1_72.lib'
1>Done building project "SOP_ComputeTangents.vcxproj" -- FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Fairly certain I have covered all my bases as far as versions and permissions go. I can't seem to find any reference to 'libhboost' anywhere on the internet or in my houdini install directory.. not sure what it is. Have read a few mentions of built in boost version in Houdini but not sure what to make of that.
Hoping someone more technically proficient might be able to point me in the right direction or get a new compile for this node. ( maybe something to do with boost changed in the SDK in 16.5 ? https://www.sidefx.com/docs/hdk/_h_d_k__changes_16_5.html [www.sidefx.com] )
