Houdini Installation issue on Manjaro
   Views 15877   Replies 26   Subscribers 6
hi guys i cant install Houdini license server on Manjaro linux, here is the output :
Cannot figure out where to put system startup scripts
Please install manually
*** NOTE ***
Some install errors seem to have occurred.
Your installation may not be complete.
Please correct any serious problems and re-install if necessary.
hi i found the solustion:
sudo mkdir /etc/init.d/
then install sesinetd, if doesn't work copy sesinetd file that i attached here to /etc/init.d/ and try to install again.
Edited by Hossein Safaei - 2019年1月18日 05:39:25
sesinetd (5.0 KB)
Hey, thanks, this fix works for ArcoLinux, too…
Update: The previous doesn't auto-start sesinetd or even register it as a service, but I managed to figure out how to write a systemd service file that works on it's own…Now one can simply ignore the “cannot figure out where to put files” error when installing houdini, and just copy this .service file to /usr/lib/systemd/system (/etc/systemd/system didn't work; it kept making the wrong symlinks and then complained that the file/service already existed), and enable+start it either by
(your-preferred-root-method) systemctl enable sesinetd; (your-preferred-root-method) systemctl start sesinetd
or via kcm-systemd (or other auto-systemd-reloading systemd GUI manager)…
sesinetd.service (413 バイト)
HongMao
sesinetd.service
Hi Hong!
Tell please, I have successfully running Houdini under last manjaro distro,
but I can't automate this environment running steps and I need to run them manually in terminal in each manjaro desktop session:
cd '/opt/hfs18.5.596'
source houdini_setup
sesinetd
Can you mind me please, how to run it with some kind of script, and where to put this script for run at boot? thanks!!!
Hey guys,
Quick updated how I am able to run on Manjaro 21.1.0.
So the issue seems to be because Houdini license is made to start its service using the outdated init.d while more modern distros have opt out towards systemd for all service management. And Arch linux and therefore Manjaro, doesn't even have init.d folder anymore. That's why on houdini install, the installer log complains about not setting up all paths or scripts properly as it is most likely (speculating here) made for a pretty old CentOS.
1. So to fix it, first I created init.d folder just as Hossein Safaei suggests - sudo mkdir /etc/init.d/
2. Then run the installer and houdini installer will make sesinetd file in there.
3. Just as HongMao suggests you can now create a systemd.service file to autorun the houdini lic service. But I had issue with his .service files as it was pointing to H17.5 folder and that is going to change when you install other Houdini versions. I also had other issues even specifying the right H18.5 folder as it is the latest version.
So I just got rid of his line there and pointed to the original /etc/init.d folder where Houdini installed the sesinetd. This way it will execute the sesinetd on autostart the same way you would do it manually from the terminal using the command: /etc/init.d/sesinetd start
So including this line
ExecStart=/etc/init.d/sesinetd start
in the .service file - which was then placed in /usr/lib/systemd/system.
You can also download my version of HongMao's sesinetd.service which works for me and it is pointing to the init.d so it should work with other houdini versions, as long as:
A) you make sure you have init.d folder in /etc and
B) Houdini installer continues to add the sesinetd file in /etc/init.d/
So download the sesinetd.service file and place it in usr/lib/systemd/system/
This should apply for other Distros as well, that are not supporting init.d anymore.
Martin
sesinetd.service (340 バイト)
Thanks Martinium!
martinium
Hey guys,
working, grand thanks!
Edited by dosyanich - 2021年11月10日 13:42:57
I got houdini 18.5 working without issues but now with hudini 19 sesinetd doesn`t seem to want to launch (except after install)
If i do sesinetd start it returns Starting Houdini License server.
but when i run stop it tells me no server found running plz start before retrying.
:EDIT Problem weirdly semi fixed itself.
Edited by TangheStudent - 2021年12月2日 03:24:06
According I did just now what Martinium suggested previously and it works for me. I am using Garuda with the Dragonized theme and its working now for me. I was having the same problem.
What I did was to run this command in the terminal sudo mkdir /etc/init.d/ and then just reinstall Houdini.
After this is checked the folder /etc/init.d/ to see if its populated and I found the sesinetd file over there. I then executed the file in a terminal and was able to in install my license.
I hope this helps
Hi, I was thinking about trying out Manjaro and Houdini 18.5. Are there any really noticeable benefits to using manjaro, and also has does Redshift work on Manjaro?
jchall
hi
about Manjaro - ideally to check youtube reviews or like this.
18.5 working well, with 470 nvidia driver.
Redshift no prob in total too.
Thanks! Ill check it out. I have not been able to get Redshift to work on Pop_Os 20.04
martinium
Hey guys,
Martin
New problem with sesinetd:
[2021-12-30 13:12:15] Licensing [Manager] - Failed to find gid from name (www-data).
[2021-12-30 13:12:15] Licensing [Manager] - Failed to find uid from name (www-data).
Did you find how to fix it? The problem still persist.
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
deviner
just write in hou support email, probably they can suggest a solution. Not a particular Manjaro issue for my taste.
one solution:
support:
sesinetd 19.0+ runs as www-data on Linux. It's possible _www or sesinetd users haven't been created on your machine causing the license server to not start.
You can try creating it manually.
It was sufficient to create a www-data user and a group with the same name and add 'myusername' to the www-group in my case
Also: add RemainAfterExit=true in your systemd service, sometimes it stops right after it starts.
https://superuser.com/a/1240000 [superuser.com]
Edited by Ivan L - 2022年11月25日 13:44:56
when i run houdini in manjaro its write me
"libGLU.so.1: cannot open shared object file: No such file or directory"
and in manjaro i can't find libGLU package soo how did you solve it?
thanks
habernir
thanks
hi! Seems like it's a part of OpenGL libraries and probably you have missed some:
thanks
