I have this small, but working pipeline in Maya with Alembic files.
Animation is cached out, and imported back in. Than shading and rendering is set up.
But I cannot seem to import any of these Alembic files into Houdini 15.5.
I get a warning right away about not being able to evaluate the file.
tried every setting in the node, but no luck. Tried to find answers here, but so far no luck.
Is there a certain way to write out Alembic files for Houdini from Maya?
cheers!
rob
Alembic import
13301 18 1- RobW
- 147 posts
- goldfarb
- 3464 posts
- RobW
- 147 posts
Hi Michael,
Yes, I am.
This works for other 3D apps, not sure why Houdini is throwing me an error.
We normally have the geo inside a little hierarchy when exported, and is imported back into the same structure.
Maybe that is the problem here?
rob
Edit: Just to add, it's Maya 2016SP5 on Win7
Edit2: Copied some of the alembic files to the desktop to see what happens, and it works. I can load both Ogawa and hdf5 files from there. So it's something network related, and it looks like Houdini cannot find the path or something.
One down, one to go ;-)
Yes, I am.
rob
Edited by RobW - 2016年5月27日 04:40:47
Apprentice Attribute / Houdini 17.0.381 / GTX 970 - driver 411.63
- RobW
- 147 posts
OK,
Back at this.
Houdini refuses to import any files, Alembic and/or FBX, from server locations. We checked all relevant rights on folders and files, and there's no problem there. It doesn't matter if the files are inside, or outside the project structure.
We tried the File>Import route, and the direct approach of getting a Alembic/File node and loading the file from there.
In all cases we get an error in Houdini.
The File>Import route gives me a ‘Import failed, Z\Projects\Goat\caches\goat.abc does not exist’
The direct approach with a node gives a ‘Error: Unable to read file “Z\Projects\Goat\caches\goat.abc”’
Also, when browsing to the cache files, they are all grayed out, until you check the sequence box. Than you can select Alembic files with a number in the name.
Really stumped on this one.
rob
Back at this.
rob
- tomtm
- 133 posts
- RobW
- 147 posts
No, it's a Win2012 Ess. server with basic shares and all the common rights set for users.
Like I said, we checked it all twice now, but Houdini just refuses to read in the files :\
But please just ask the network guy/gal, as there could be a ‘a-ha’ moment here
cheers!
rob
edit: It is something specific to Houdini, as Maya and Softimage can read in these files just fine. Odd.
cheers!
rob
Edited by RobW - 2016年5月30日 05:20:46
- goldfarb
- 3464 posts
- RobW
- 147 posts
Hi Michael,
Everything has a ‘proper’ path and filename, so no spaces in between.
Not sure what to log here, but I'll pass it along to your team.
Is there any way to log stuff from the command window or such? To help with the search?
rob
rob
Edited by RobW - 2016年5月30日 09:51:43
- tomtm
- 133 posts
- RobW
- 147 posts
Just got word from the support peeps.
It has to do with the HOUDINI_ACCESS_METHOD environment variable.
So if you add this line to your houdini.env file, it will work as expected:
HOUDINI_ACCESS_METHOD = 2
More on this to be found here. [archive.sidefx.com]
cheers for the reply though, much appreciated!
rob
rob
- harrye123
tomtm
Do you load it from a NAS Server brand Synology?
We also had issue loading assets in Houdini.
If so I would need to ask what our network specialist has changed.
Thanks a lot! you just saved me a lot of time- I had this exact problem. I moved the alembic file from the nas to a local disk and it worked straight away. Cheers
- The3DStig
- 129 posts
- joshspivey
- jamesdelf
- 7 posts
How is this still not fixed?!
I just made an ABC (and an FBX to compare) in Syntheyes and saved to the server (Windows mapped drive). The alembic and fbx both fail to import. They both import fine to Maya.
I found this thread. I thought, surely not... that is from 5 years ago
I copied the files to my D drive and boom they both import fine.
Yes there is an environment variable patch - I tested and yes that fixes it.
But this should have been fixed years before I have to spend 20 mins fighting, testing, cursing, searching...
Please fix this.
At the very least put a note in the docs when you click on the '?' in the Alembic Import Window
thanks to RobW for posting the solution.
Houdini Indie v19.0.383
Please fix this.
- Werner Ziemerink
- 1268 posts
- RobW
- 147 posts
- ChadStevens_94
- R0B
- 7 posts
- RobW
- 147 posts
