override instanced static mesh's material
   3507   2   0
Is that possible to change instanced static mesh's material using "unreal_uproperty_"?
I tried many different name for the material element 0. but have no luck.
Any tips?
Edited by anon_user_10187590 - 2022年2月10日 00:41:06
Couldn't find anyway to override instance static mesh's material.
So I converted my static mesh into Blueprint actor then make a material instance type variable.
Then use unreal_uproperty_XXX to override the material.
I dont think this is a smartest way to do it.
Hope it helps.
Exactly looking for a solution to that as I want to override only the first material on the instances and not all the material ID.
