reversefoot sop not work correctly
   1819   3   0
Reversefoot sop throws an error in last buids of houdini.
But in 19.0.383 Reversefoot work correctly.
Edited by raistlinf - 2022年6月16日 03:48:10
ReverseFootError.hipnc (180.2 KB)
if you use the roll parameter it seems to work fine, the controls however seems to be broken.
You should send in a bug report
Here is how you can set up your own custom one its pretty straight forward
CustomReverseFoot.hipnc (217.6 KB)
Thanks for pointing this out. This has been fixed and should appear so in the next daily build.
