triplanar map materialx
8629 18 4-
- Piledriver
- 99 posts
- 8070 posts
- Piledriver
- 99 posts
- Piledriver
- 99 posts
- 8070 posts
Piledriver
i open the scene but i don't understand why don't work i create the new one USD Coordys node
It's pretty picky about hierarchy, I had to experiment a bit. Check out the help and example file under the coordsys node.
Piledriver
this coordinate system node work only for cpu
Oh, bummer. I forgot about that limitation. For XPU, there's always multiply and add nodes.
Edited by jsmack - 2022年8月1日 00:28:37
- Piledriver
- 99 posts
- 8070 posts
Piledriver
i tried to check the help if you mean the doc its not so clear.... hope in future sidefx implement better this triplanar because in other render engines and also with principled shader its a lot simpler
what are you having trouble with? The coordsys or the triplanar texture? The coordsys is by no means required for the triplanar texture, it's just a convenient way to transform it. As for enriching the features of the node itself, since it comes from MaterialX, it would be up to them to adopt a more complex node. Alternatively, sidefx could implement a karma-specific node, but there would have to be significant demand for that.
It's also not impossible to just build your own triplanar projection yourself based on the math used by the mantra version.
- Piledriver
- 99 posts
the coordsys it's my issue now i don't just unrderstand how name the attribute to make the scale work to triplanar node, i mean at the staart of this conversation the issue itself it was about the fact that i can't scale or rotate the texture for triplanar, about rotating i solved that putting a mtlxrotate node but for the scale there isn't a node to allow that, but just i give up because i'm tired, so just i don't use materialx for triplanar mapping. maybe in future when this are done better i could do that but i don't want become crazy to make something where other render engine just do in a easier way
- 8070 posts
Piledriver
scale is even easier, just use the multiply node. Same as with Mantra shaders.
- Piledriver
- 99 posts
- 8070 posts
- Piledriver
- 99 posts
- 8070 posts
- 8993 posts
I understand the frustration
I don't really get how MtlX is missing so many basic nodes, it feels like a proof of concept, but hopefully with more adoption the development will accelerate
there is Place2D node which has nice transform controls, especially Pivot which can be tedious to manage with just simple math nodes especially without full matrix math library
but Place3D is nowhere to be found, one shouldn't have to resort to external coordsys relationship or building their own math libraries for relatively basic functionality
Edited by tamte - 2022年8月1日 22:28:30
- Piledriver
- 99 posts
- Fabazo
- 4 posts
I'm also trying to get the whole triplanar thing to work on my end. And through reading everything above I can replicate everything except for properly rotating each side of the triplanar individually.
I inserted a mtlxrotate3d node and rotated the X-axis 90 degrees, which does work for the X-axis's side, but for the rest of the sides my texture just becomes warped (see image).
Am i inserting the mtlxrotate3d node in the right place or what's going on? I basically want my texture to be rotated so that all sides display the grunge flowing in the same direction. I also tried splitting the "vectors" individually and tried to scale them through that, but no luck there.
- Kwesikwaa
- 20 posts
Fabazo
hello, were you able to resolve this
- Fabazo
- 4 posts
KwesikwaaFabazo
I wasn’t, no. I haven’t used the newer versions of Houdini though since I posted here.. so maybe there’s a way now?
- cdenny
- 3 posts
I've just posted an open source version of some tools for Houdini I've built over the years, including a MtlX Triplanar node that solves this rotation issue. Details can be found on the repo's README [github.com]. Please let me know what you think and if you run into any errors - I'm a one man team so the more eyes the better.
https://github.com/chris-denny/CDFXHouTools [github.com]
Chris
Chris
