Saved the sequence of usds, then in usd stich clip used this sequence, checked for correct path, outputted and there was no error. But when I load it back with the reference node it gives me this warning, the scene is empty. Did someone faced with something similar?
Warning
Invalid clips specified for prim </Tree>: Clip 1 cannot be active at time 78.000 in 'active' because clip 0 was already specified as active at this time.
Warning
Invalid clips specified for prim </Tree_A1_stiched_v4>: Clip 1 cannot be active at time 78.000 in 'active' because clip 0 was already specified as active at this time.
SOLVED
The mistake were because I used sphere and cone LOP node. It need to be loaded form SOP with the Layer Save Path turned on, then it will work.
USD Stich clip Warning "Clip 1 cannot be active at time"
1451 1 1- lexpaintre
- 8 posts
- AhmedHindy
- 136 posts
