Fastest way to compute the closest distance between 2 lines?
   3485   7   2
Hi folks,
I was hoping somebody could help me out.
xyzdist() might look at a whole polygon/surface, but it still has to look from one point; it doesn't look 'from' a whole primitive, if you know what I mean.
See the picture. It isn't a point where the lines nearly intersect.
How to find the closest distance in the most resource-efficient way ?
Thanks.
Edit: preferably in VEX, since I see this ‘primdist’ function in HScript which seems to do what I want, but I am writing VEX because HScript is just for parameters, right?
Edited by OdFotan - 2022年11月17日 07:11:20
Screenshot 2022-11-17 at 11.50.38.png (667.8 KB)
measure_primdist.hiplc (108.2 KB)
I don't have a proper math solution to this, but I think with bruteforce you can get a good enough approximation.
You resample one of the curve first, then xyzdist() and finally attrib promote to get the min distance.
Or probably more performant if you use Ray Sop instead of xyzdist()
Edited by Andr - 2022年11月17日 08:51:50
Use the xyzdist function in a 'for each'sop lop. Use iteration odd/even number to switch alternatively between polygon/surface for each search from, search too; Using the result position (primuv() function of the xyzdist() function result)in each case.
Set the number of iterations of the for each loop to get desired granularity/precision of the answer you want.
Just do a manual delete to start with only those two near polyline segments and begin with the search at one endpoint.
Edited by BabaJ - 2022年11月17日 11:36:11
OdFotan
Hi, just for fun I had a go, not really expecting very much.
This reminded me of some javascript code I did once that determined the distance between a bunch of bouncing balls. That is why I wanted to test this out.
However, as you mention there is no point exactly at the closest distance. So one idea I had was to first find the points that was closest, and then make a new line pair only for those points. These lines should be resampled to any desired detail. Then finally the distance is measured to the given accuracy level.
Although I do not think we will use Python for this, I just played with the numbers, and share it just for fun.
Edit: After thinking a bit about this, probably the entire lines should be resampled first, if there is no node/function that can simply "walk/follow" the entire lines and check the distances.
Edited by SWest - 2022年11月17日 17:31:41
swest_screen_capture_20221117_2314.mp4 (3.3 MB)
Here's some VEX that might help
#define EPSILON 0.0000001
// Given 2 lines such as line1 passes through P1 & P2, and line2 passes through P3 & P4,
// find the segment intersecting the 2 lines passing through the point Pa on line1, and Pb on line2
// mua is the signed distance of the intersection point on line1 to P1
// mub is the signed distance of the intersection point on line2 to P3
// returns 1 in case of success, 0 otherwise (2 lines are parallel)
int LineLineIntersect(vector P1, P2, P3, P4, Pa, Pb; float mua, mub)
   vector p13 = P1 - P3;
   vector p43 = P4 - P3;
   if (length(p43) < EPSILON) return 0;
   vector p21 = P2 - P1;
   if (length(p21) < EPSILON) return 0;
   float d1343 = dot(p13, p43);
   float d4321 = dot(p43, p21);
   float d1321 = dot(p13, p21);
   float d4343 = dot(p43, p43);
   float d2121 = dot(p21, p21);
   float denom = d2121 * d4343 - d4321 * d4321;
   if (abs(denom) < EPSILON) return 0;
   float numer = d1343 * d4321 - d1321 * d4343;
   mua = numer / denom;
   mub = (d1343 + d4321 * mua) / d4343;
   Pa = P1 + (p21 * mua);
   Pb = P3 + (p43 * mub);
   return 1;
Then all you need is the length of Pa - Pb.
If you're looking for distance between 2 segments, then a quick internet search yields plenty of examples:
https://stackoverflow.com/questions/2824478/shortest-distance-between-two-line-segments [stackoverflow.com]
npetit
At a quick glance, is something like this ‘KD tree’ involved there?
https://youtu.be/BK5x7IUTIyU [youtu.be]
I recently saw this video but I am still very new to math so. But that video also seems to focus ‘from one point’ (gonna study your code later).
Edited by SlowlyLearningMath_houGuy - 2022年11月21日 11:01:59
Hi here is another way to do this, a little bit simpler I think. You can use a intersection analysis with a high proximity tolerance to get the point where they would intersect. Then ray the point to each prim and calculate the dist between the two points.
Edited by willh - 2022年11月21日 04:47:09
prim_proximity_dist.hiplc (124.5 KB)
willh
It is beautiful, like a piece of art. Thank you for sharing.
