Why is this Fluid surface flickering still happen?
   3413   2   0
hye, im still facing the fluid surface flickering after i had follow all suggestion on the internet.
*I'm making slow motion fluid movement, 120FPS
this is what i did:
1. Particle Fluid Surface Node - Turn On Limit Refinement
2. Particle Fluid Surface Node - Turn Off Rebuild SDF (inside node content)
3. Particle Fluid Surface Node - Change to Spherical Method
3. Particle Fluid Surface Node - Set Adaptivity to 0
3. Flip Solver Node - Reseeding Turn Off (but AutoDOPNetwork lock the option, so i cant turn Off)
Flicker FLuid.mov (11.1 MB)
SideFX question.jpg (211.6 KB)
SideFX question2.jpg (124.2 KB)
SideFX question3.jpg (91.1 KB)
SideFX question4.jpg (132.0 KB)
SideFX question5.jpg (115.7 KB)
No replies?
Seems like you need smaller particle separation.
Edited by Heileif - 2023年9月13日 18:03:47
