I feel like I am missing something, I would like to use Karma XPU for an upcoming project. I have a simple material setup with a mix between a diffuse and a metallic MTLX shader. I am getting the below error:
KarmaXPU: Material _sg_s_5510EB952FE4D00E has type not handled by XPU, skipped
I realize it is saying the "mix shader" is not supported by XPU.
Is there a workaround? It works fine with CPU.
This seems like such a basic need that it is making me think I am doing something wrong. There are so many seemingly abstract nodes for XPU why would devs omit the MTLXMIX?
Karma XPU MTLX "MixShader"?
3232 10 3- icyou2020
- 29 posts
- brians
- 531 posts
Sorry, mixing of arbitrary materials is not yet supported by XPU
XPU limitations are listed here
https://www.sidefx.com/docs/houdini/solaris/karma_xpu.html#summary [www.sidefx.com]
(this falls under the category of "PBR" nodes)
We are working on addressing this though, so watch this space
- eyellusion
- 7 posts
brians
Hey there,
just tested this in Karma XPU in the new H20 release, but it still doesn't seem to be supported to mix surfaces, right? Or am I missing something here?
- brians
- 531 posts
you can mix two MtlxStandardSurfaces via a MtlxMix node
- eyellusion
- 7 posts
brians
Hey brians,
thanks for the reply. That is what I am already using, it works fine in Karma CPU but the same shader renders just grey in XPU currently. I do not get the same error as in H 19.5 saying it doesn't support MtlxMix nodes anymore but it still doesn't render correctly.
- brians
- 531 posts
- eyellusion
- 7 posts
brians
I'm not sure what issue you have.
But here is an example.
Does it work for you?
Hey,
Yes that example file works on my side as well. I noticed however when I add another MtlxMix node after that one and add another surface mix it fails to render on XPU which is what I did in my project as well to layer different shaders, still works fine on CPU though (attached example). Is that a Karma XPU limitation at the moment then?
- brians
- 531 posts
- eyellusion
- 7 posts
- zhenglu
- NadavZohar
- 6 posts
