can't get background plate to render (Houdini 20)
2474 6 3- gladstein
- 16 posts
- spinori
- 15 posts
- gladstein
- 16 posts
- npetit
- 413 posts
- gladstein
- 16 posts
- dlee
- 444 posts
Hi. The background LOP assumes that the elements will be rendered separately and tweaked/composited in comp, hence why the slapcomp only happens in IPR for previewing. But if you wish to render out what you see in the viewport you can certainly do so: place "Render Settings Edit" node after "karmarendersettings" LOP, under Karma->Global->Image, change "Use Background" property to "On"
- gladstein
- 16 posts
