How to color correct the HDR in solaris?
   1604   4   0
We can't use cops inside solaris?right?The dome light really needs some simple color correction function.
wanglifu
Maybe the light filter will do the trick?
jsmack
wanglifu
I don't think so.
wanglifu
jsmack
wanglifu
I don't think so.
Using the light filter gel worked for me. I can use basic colour correction like gamma, saturation, exposure etc on my HDRI. For some reason it doesn't update the display of the HDRI but still affects whatever it's lighting. However if you enable "Render Light Geometry" then you can see the changes being displayed, although it was still bit buggy.
Nathan_T_Anderson
It won't update the display because that's using openGL. The light filter is a shader applied by karma only.
