Why do multiparms waste so much screen space? Why so wide?
2177 8 1- kodra
- 373 posts
- HGaal
- 102 posts
- Mike_A
- 280 posts
- kodra
- 373 posts
It's probably the second worse part of Houdini's UI.
The worse part is, of course, this tiny field:
SideFX UI logic: this is the field that takes the longest value (multiple lines of Python) in the whole Operator Type Properties window, so we give it the least room. It's almost like they were trying to be an anti-example in UI design textbooks...
Edited by kodra - 2023年12月18日 20:08:57
- wanglifu
- 186 posts
- Andr
- 899 posts
A couple of tricks to reclaim some precious space in the parameter panel:
1) Nest the multiparm folder inside another folder. Set the multiparm folder to hidden. This way you get rid of the buttons for adding and clearing each instance.
2) If you need to force all way to the left any parameter, just insert a dummy parameter before (I usually use a label parm), set it to invisible and join it horizontally to the next parameter you want to move to the left.
- kodra
- 373 posts
- mandrake0
- 644 posts
i think it is the right time for a UI RFE!
the vfxplatform it notes for this year a big QT upgrade.
https://vfxplatform.com/ [vfxplatform.com]
How to RFE:
https://www.sidefx.com/forum/topic/25347/ [www.sidefx.com]
How to RFE:
- kodra
- 373 posts
mandrake0
How to RFE:
The amount of RFEs and bug reports I sent to SideFX could qualify me as a full-time QA working for them.
Or put me on a spammer list.
