Texture from Substance
   1039   3   1
Hi guys!
I have an issue that is turning me crazy.
So i exported a Hi res obj from my convertheightfield1 in Houdini:
and a Low res obj from a uv layout:
Everything looks fine in Substance as you can see:
But when i export the textures and import it in Houdini it looks like the texture map rotate to 90°:
Do you guys have any idea what happened here?
Edited by VinceP - 2024年1月15日 16:44:06
Ok so i tried to work with just the High resolution terrain on Sbustance and it's working.
I don't know what i did wrong but when i use the Low res file and then i bake with the High res it's a mess in Houdini.
Did you use a Hipoly cage when baking in Substance? I'm pretty new to Houdini and Substance, but something similar happened to me a while back, and using a high poly as the cage solved my issue.
I don't know if you are talking about this:
But i tried with just the High res file as the cage and it's not working either.
Maybe i'm doing something wrong ^^
Edited by VinceP - 2024年1月20日 11:24:53
