Update existing node menu items with Python 'OnCreaded'
   Views 620   Replies 0   Subscribers 1
Goal: add an item to the Karma LOP -> Image Output -> Filters -> Tonemap menu item and save the updated parameter interface with Python.
Issue: menu item is updated with a new item but parameter interface (parmTemplateGroup()) doesn't save it.
It doesn't show in UI but via print()it shows.
Context:
  • Karma LOP.
  • Created script name: karmarenderproperties_OnCreated.py
  • Created script location: C:\Program Files\Side Effects Software\Houdini 20.0.653\houdini\scripts\lop
Code I use to add an additional menu item to already existing ones:
# get Karma LOP node
node = kwargs['node']
# get all parameters from Karma LOP
parm_group = node.parmTemplateGroup()
# get 'tonemap' parameter
tone_map_param = node.parm('tonemap')
# get parameters from 'tonemap'
tone_map_template = tone_map_param.parmTemplate()
# Update the menu item template with the new item template
tone_map_template.setMenuItems(tone_map_template.menuItems() + ('AnimGraphLab',))
tone_map_template.setMenuLabels(tone_map_template.menuLabels() + ('AnimGraphLab',))
print(parm_group.find('tonemap').menuLabels()) # ('No Tonemapping', 'Reinhard', 'Ward', 'Unreal', 'Aces', 'Hable', 'Hable2')
# Replace the existing menu template with the updated one
parm_group.replace('tonemap', tone_map_template)
print(parm_group.find('tonemap').menuLabels()) # ('No Tonemapping', 'Reinhard', 'Ward', 'Unreal', 'Aces', 'Hable', 'Hable2', 'AnimGraphLab')
# save Karma LOP parameters layout with new updates
node.setParmTemplateGroup(parm_group)
I belive something is with node.setParmTemplateGroup(parm_group)since parm_group.replace()adds a new item.
I've tried to create the exact same menu via StringParmTemplate [www.sidefx.com] because node.parm('tonemap')type is a String [www.sidefx.com], and it was updated (image below):
menu_template = hou.StringParmTemplate(name='tone_map',
                                     label='Tonemap',
                                     num_components=1,
                                     menu_items=('off', 'ward', 'unreal', 'aces', 'eminem'),
                                     menu_labels=('no tonemap', 'ward', 'unreal', 'aces', 'Eminem'),
# insert menu items as a very first paramter
param_to_insert_before = parm_group.find("quicksetup")
parm_group.insertBefore(param_to_insert_before, menu_template)
desired_label = "AnimGraphLab"
existing_labels = menu_template.menuLabels()
if desired_label not in existing_labels:
  new_menu_items = menu_template.menuItems() + (desired_label,)
  new_menu_labels = existing_labels + (desired_label,)
  # Update the menu template
  menu_template.setMenuItems(new_menu_items)
  menu_template.setMenuLabels(new_menu_labels)
# Update the parameter template group with the modified menu
parm_group.replace('tone_map', menu_template)
What am I doing wrong?
Thank you.
Edited by AnimGraphLab - 2024年5月6日 04:09:42
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
