I am trying to access the point indices prims are made up of in Python.
Currently I am doing this with:
for k in geo.prims():
MyCurrentFace = k
NumVertsCurrentFace = MyCurrentFace.numVertices()
for Verts in MyCurrentFace.vertices():
VertsCurrentFace = Verts.point().number()
print VertsCurrentFace
It works but it is relatively slow.
In another thread where I asked how to access point positions I was told that it would be very fast with using:
hou.Geometry.pointFloatAttribValues(geo,“P”)
That worked very fast.
So my question is, is it possible to get the point indices of individual faces in a similar way?
I have so far tried to create relevant Attributs with nodes such as the attribcreate node, but I wasn´t sucessful.
I did some other tests and manged to create Attributes such as Normals and similar things with nodes which I was then able to access with Python. But I have so far not managed to create Attributes for point index per prim.
Get point indices in prims with Python
4865 2 0-
- samfisher
- 9 posts
- Stalkerx777
- 183 posts
No other way. If need particular prim, or range of prims, better use generator (iterPrims):
points_ids = [vtx.point().number() for vtx in geo.iterPrims().vertices()]
If you'r iterating over all prims there is no big difference in speed between prims() and iterPrims() other than more memory consumption.
Aleksei Rusev
Sr. Graphics Tools Engineer @ Nvidia
- perpen
- 60 posts
This is what I use to avoid looping over the geometry in python (my example is strictly for triangles but you can modify it)
First add a string prim attribute with the vertices per primitve:
Then after that in a python geo node:
i[]@face_idx = primpoints(0, @primnum); s@face_indices = string(itoa(i[]@face_idx[0]) + "," + itoa(i[]@face_idx[1]) + "," + itoa(i[]@face_idx[2]));
face_indices = np.array(geo.primStringAttribValues("face_indices")) flat_list = ','.join(face_indices).split(',') face_indices = np.array(flat_list, dtype=np.int32).reshape(-1,3)
Edited by perpen - 2024年5月23日 19:07:56
