MultiParm Block list - return the attribute menu script
   468   1   0
How can I achieve functionality similar to "Attribute Swap", where the dropdown menu returns the corresponding data types based on the attribute type?
To ensure that your script handles multiple class parameters without overwriting each other and executes correctly, you need to accumulate the results for each class parameter and avoid reassigning the result list. Here's an updated script that ensures the attributes for each class are correctly added to the final result:
r = []
node = kwargs['node']
inputs = node.inputs()
number_casts = node.evalParm("number_casts")
if inputs and inputs[0]:
    geo = inputs[0].geometry()
    if geo:
#遍历每个属性类别
        for i in range(1, number_casts + 1):
            c = node.parm('class'+str(i)).evalAsString()
            if c == 'detail':
                attrs = geo.globalAttribs()
            elif c == 'primitive':
                attrs = geo.primAttribs()
            elif c == 'point':
                attrs = geo.pointAttribs()
            else: # vertex
                attrs = geo.vertexAttribs()
        for a in attrs:
            r.extend([a.name(), a.name()])
return r
Is there anyone who can help guide me? Thank you very much
To avoid reinventing the wheel you can maybe use hou.SopNode.generateInputAttribMenu() [www.sidefx.com]
Or hou.Geometry.generateAttribMenu() [www.sidefx.com]
