State of modeling in H20
6183 32 1-
- PolyMarvels
- 916 posts
Hey folks, it's been more than two years now since I started diving into modeling in Houdini. While I was hearing only bad things about modeling , I wanted to see if there was more than people might know about it. And the short answer is, hell YEA!!!
Not only did I manage to find a way to do modeling in Houdini, but I also found a way where one can have a nice flow while modeling, and honestly as someone who modeled in pretty much all DCC's, even Plasticity, I can say that Houdini does some things much better then any other DCC, not to mention the fact that things staying procedural, even if you call it destructive modeling. That's why I started to call modeling in Houdini Hybrid modeling.
In case there are people interested, here you can find the environment and setup I am using plus some of the modeling I did:
https://miro.com/app/board/uXjVP06Hcz4=/?share_link_id=829218827858 [miro.com]
It's all Houdini and some of the textures are from Greyscalegorilla. I did not use any plugins. I also spent more than 3000h exploring/researching all of this.
Now, is everything perfect, no. Is there a potential, hell yea... a huge one, but in the end, its up to SF to decide where it pushes modeling if ever they decide to do something about it.
Cheers and stay well fellow artists.
Igor
P.S. - I have no intentions to argue against or for Houdini's modeling capabilities, I don't, I am only here to show what is possible if you try, hard.
Igor
Edited by PolyMarvels - 2024年5月21日 16:26:46
QA Specialist at Greyscalegorilla |PolyMarvels YT: https://www.youtube.com/channel/UCqXuTLiaL-jqvn3LK1XlwHg [www.youtube.com] | Instagram: https://www.instagram.com/polymarvels/?hl=en [www.instagram.com]
- Enter The VFX
- PolyMarvels
- 916 posts
Enter The VFXYou are most welcome. If you have any questions feel free to ask or join the PM discord channel. 😊
Thanks for sharing your insights and experiences, Igor! The modeling environment sheet looks really helpful!
Cheers!
- kodra
- 373 posts
- kodra
- 373 posts
- PolyMarvels
- 916 posts
kodraHere you go https://discord.gg/hux3DkbrMx [discord.gg]
Where is the discord server link though?
, also this is my YT channel https://www.youtube.com/channel/UCqXuTLiaL-jqvn3LK1XlwHg [www.youtube.com] , I just uploaded new video.
- raincole
- 558 posts
- PolyMarvels
- 916 posts
raincole
That's cool, but it seems that you hijack tab key for construction plane. Then how do you call the tab menu in scene viewer? It doesn't feel like a good idea to change how tab works, as it's THE most used hotkey in Houdini.
Thank you, I don't use it at all, if I do, I assign it to Shift+Tab in the viewport or call it from Node Network with just Tab. The point of modeling things like this is to actually avoid typing to call nodes. I have everything I need within shortcuts and Radial Menus + shelves.
Edited by PolyMarvels - 2024年6月25日 09:33:54
- raincole
- 558 posts
PolyMarvels
Calling something from Scene Viewer and Network View can result in very different behavior, even the name is the same, so they're not interchangeable. I guess Shift+Tab is good enough though.
- PolyMarvels
- 916 posts
raincolePolyMarvels
Again, the point was not to use it at all because it's not the way to do modeling, thus, I have put CP on Tab, as I am using that a lot, just like I set Accept/Enter to `shortcut. It saves you a lot of pain in the long run. Reaching Enter all the time is annoying and tiring.
- kodra
- 373 posts
A quick question: how did you jump from PolyBevel SOP to Tube SOP at 10:16 here:
https://youtu.be/ROcOJfJhKQQ?t=614 [youtu.be]
And jumped back to PolyBevel at 10:25
https://youtu.be/ROcOJfJhKQQ?t=625 [youtu.be]
Edited by kodra - 2024年6月26日 00:36:40
- PolyMarvels
- 916 posts
kodra
PageUp and PageDown for going up and down the stream of nodes and Home and End to jump to 1st and last node in the stream. Those keys are above your keyboard arrows (beside delete and insert).
In my case I bind those to my mouse buttons which makes things super fast and convenient to use.
- kodra
- 373 posts
- PolyMarvels
- 916 posts
kodraIt doesn't hurt to repeat.
Thank you for the answer. I just realized you actually explained it later in the video
- kodra
- 373 posts
- PolyMarvels
- 916 posts
kodraUnfortunately that was introduced after 20.0.506 and never fixed to this day. I didnt report as I just dont wanna bother at this point. And to remove that just hover over the HUD, click right mouse button and uncheck 'Visible'.
I've been experiencing another issue. I've notice the same issue in your video as well:Image Not Found
There are "ghost" HUD handles at the bottom left corner. I've got these from time to time. Have you found a way to get rid of them (without resetting the whole viewport)? Or have you reported this to SideFX?
- kodra
- 373 posts
PolyMarvelskodraUnfortunately that was introduced after 20.0.506 and never fixed to this day. I didnt report as I just dont wanna bother at this point. And to remove that just hover over the HUD, click right mouse button and uncheck 'Visible'.
Well when I right click on the ghost HUD handles it throws Python exceptions and doesn't show a context menu, so I can't even uncheck 'Visible'.
I'd like to report it to SideFX but so far I can't make the exact steps to reproduce this... they just randomly appear from time to time.
Edited by kodra - 2024年6月26日 12:31:07
- PolyMarvels
- 916 posts
kodraPolyMarvelskodraUnfortunately that was introduced after 20.0.506 and never fixed to this day. I didnt report as I just dont wanna bother at this point. And to remove that just hover over the HUD, click right mouse button and uncheck 'Visible'.
Just go with 20.0.506 build and you'll be fine. You are not missing anything.
- kodra
- 373 posts
- PolyMarvels
- 916 posts
kodraAh that's a bummer. Then just report the issue to SideFX, I will too so maybe it gets fixed. Thanks for letting me know about the typo, ill uodate it right now. And yes, it's ALT + S for Subdivide.
I can't. There was an important fix in 20.0.6xx about KineFX that is needed for my workflow. Thank for your suggestion though.
I also find a minor typo here:Image Not Found
Subdivide should be Alt+S right?
By the way, are you able to follow workflows to model something, even simple stuff?
