Hey all, I'm working on an HDA which utilizes an on-disk python library and I was hoping I could use the same directory structure to house my help docs so I could update them without having to rebuild the node every time I update the help docs. I could run it on our web server, but I would prefer to make it available offline and harden it against service outages on our web server. Unfortunately, I cannot seem to get it to work. When I click the help button, nothing happens. Anyone know if this is possible or do I just need to setup a web server for it. Also, I need it to be relative as users may have different install directory paths for it.
Note: I have had to switch my HOUDINI_EXTERNAL_HELP_BROWSER env variable to true as something is broken in my Houdini installs that causes an infinite loop when I try to use Houdini's built in browser for them. Not sure if that has something to do with it or not though.
Relative reference to file for HelpUrl on an HDA
247 0 0-
- Adam Ferestad
- 29 posts
