HDK Warning: GUI_PrimClusterMeshHook
   2144   11   3
I'm getting this warning when loading at H20 scene into H20.5
HDK Warning: GUI_PrimClusterMeshHook and GUI_PrimClusterMeshHook have the same priority (0)
HDK Warning: GUI_PrimClusterMeshHook and GUI_PrimClusterMeshHook have the same priority (1)
Can not find any info on this. I am having problems rendering (with Redshift) though. Is it related - no idea.
Any ideas?
Pete
Is it only if you have redshift installed? Does uninstalling redshift still give those print outs?
I disabled redshift via the houdini.env.
Started H20.5 (not loading a file) and I get.
I don't think that's the same thing. I don't get these on a stock Houdini 20.5.278 install so I think something in your environment is perhaps doubling out the search path leading to things being loaded twice. Try:
- Make sure Houdini is NOT running anywhere
- Rename your $HOME/houdini20.5 directory to something else
- Start Houdini again
Definitely Redshift env variables bringing this error. Maybe because redshift official install for H20.5 isn't available yet. I had to download plugins from custom builds section. Maybe this is why.
Oh, the 20.0 builds of RedShift probably don't work with 20.5.
wayward
Any ideas?
Pete
Windows 11 or 10 ?
For me same message!
Windows 11!
Edited by spiderbr - 2024年7月22日 10:33:41
I hear that this should be fixed for tomorrow's daily build.
spiderbr
Windows 11!
In maxon forum problem fix. no use houdini env instead of this .json file in packages folder
Bonjour à tous ! nouvel sur Forum.
wayward
Any ideas?
Pete
wayward
Any ideas?
Pete
Hello everyone! New to the Forum.
After some checks, I believe these messages are due to MOPS in the file . ENV
Try to delete it to see, it worked for me but I immediately put it back because I just came from C4D and you know what the MOPS mean for a C4D user
I hope it works for you if you can do without MOPS.
Greetings!
Capture d'écran 2024-09-12 142857.png (6.8 KB)
MOPs can't cause HDK errors. The error is likely due to some other plugin that you have in the C:\Users\XXX\OneDrive\Documents\Houdini_Plugins path. Remove that path from HOUDINI_PATH and the error will likely be fixed.
