hou.ui.reloadColorScheme()
Made a modern/cleaner UI theme
18519 22 4- AslakKS
- 185 posts
- coccarolla
- 71 posts
oldteapot7
I was playing with those .hcs files trying to change animation curves editor colours for more looking like in MAYA but man... its such a chaos in nameing convention and everything.
Main problem was that i had to edit color values, save file and then restart Houdini wich was time consuming.
But mayby there is easiest way for updating changed colors on UI immediately?
Using VEX command or perheps Python?
Anyway i wish that there was something like in Zbrush where you can play with every UI paremeter color and set it like you really like. (With realtime feedback on screen)
You can save the file in your text editor and then hit reload in color settings in Houdini and it will update. No restart requiered.
- coccarolla
- 71 posts
