I have a project where textures that were working just fine in Houdini 20.5.278 with MTLX in Solaris are now showing up with weird glitches. (see attached screenshot)
I even disconnected the image textures and just tried it with an mtlx standard surface with white base color and the problem persisted.
I tried closing and reopening the scene view to see if it was a bug, but nothing has changed.
What else should I try here?
thanks,
MTLX glitch with textures
719 2 1- dhuiting
- 38 posts
- Polybud
- 14 posts
Did you took a look, as what non desirable attributed had been smuggled into the SOP net? It could happen accidently by a miss click in the SOP network. After you dropped an attribute delete, try to regenerate the geo's normal attribute. Also take a blink on a normal render VAR path - what it shows on the problematic field. I know these are simple suggestions, but I'm sure that the geo has something not wanted. The mentioned version worked well on my side with old projects.
- dhuiting
- 38 posts
Polybud
Thank you Polybud!
Good news. I fixed the problem by adding a time shift set to frame 1, and then attribute copy for the uv attribute on vertex back to the animated geo.
I appreciate the suggestion to check the render VAR path. I will keep that in mind in the future.
thanks!
-Dan Huiting
