Exception in thread Thread-2:
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\threading.py”, line 808, in __bootstrap_inner
self.run()
File “C: \PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hou.py”, line 68171, in __threadRun
self.__run()
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\threading.py”, line 761, in run
self.__target(*self.__args, **self.__kwargs)
File “C: /PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hdefereval.py”, line 142, in <lambda>
thread = threading.Thread(target=lambda: function(*args, **kwargs))
File “C: /PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hdefereval.py”, line 162, in thread_code
it.next()
File “C: /PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\sas\localassets.py”, line 371, in check_for_shelf_tool_assets
shelf_tool_assets = StoreAPI(session_data).get_shelf_tool_assets()
File “C: /PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hutil\api.py”, line 144, in __call__
**self.kwargs_for_read_url(*args, **kwargs))
File “C: /PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hutil\web.py”, line 31, in read_url
disable_proxy=disable_proxy)
File “C: /PROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hutil\web.py”, line 143, in _create_url_connection
url_request, post_data, *extra_urlopen_args)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\urllib2.py”, line 127, in urlopen
return _opener.open(url, data, timeout)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\urllib2.py”, line 404, in open
response = self._open(req, data)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\urllib2.py”, line 422, in _open
‘_open’, req)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\urllib2.py”, line 382, in _call_chain
result = func(*args)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\urllib2.py”, line 1214, in http_open
return self.do_open(httplib.HTTPConnection, req)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\urllib2.py”, line 1187, in do_open
r = h.getresponse(buffering=True)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\httplib.py”, line 1045, in getresponse
response.begin()
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\httplib.py”, line 409, in begin
version, status, reason = self._read_status()
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\httplib.py”, line 365, in _read_status
line = self.fp.readline(_MAXLINE + 1)
File “C: \PROGRA~1\SIDEEF~1\HOUDIN~1.416\python27\lib\socket.py”, line 476, in readline
data = self._sock.recv(self._rbufsize)
error: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Traceback (most recent call last) [solved]
7081 4 0- albehany
- 12 posts
Hello guys i have this error and not sure how can i fix it any idea why this happened??
Edited by albehany - 2018年12月17日 11:58:03
- slowpixel
- albehany
- 12 posts
- bindugin
- jomaro
- 102 posts
albehany
thank to awesome people at sideFX support the problem was in the HOUDINI_PATH not setup correctly so we fix it and it's gone the error
How did you solve your problem?
I am having this error:
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/heightfield_drawmask?Sop/heightfield_drawmask
Error running event handler:
File "Sop/heightfield_paint, ViewerStateModule", line 8, in <module>
File "C:\Program Files\Side Effects Software\Houdini 20.5.314\python311\lib\site-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'sidefx_stroke'
File "Sop/heightfield_paint, opdef:/Sop/heightfield_paint?ViewerStateInstall", line 1, in <module>
File "C:\PROGRA~1/Side Effects Software/Houdini 20.5.314/houdini/python3.11libs\viewerstate\utils.py", line 1007, in register_pystate_embedded
raise ViewerStateException(
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/heightfield_paint?Sop/heightfield_paint
File "Sop/attribpaint, ViewerStateModule", line 6, in <module>
File "Sop/attribpaint, opdef:/Sop/attribpaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/attribpaint?Sop/attribpaint
File "Sop/drawcurve, ViewerStateModule", line 11, in <module>
File "Sop/drawcurve, opdef:/Sop/drawcurve?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/drawcurve?Sop/drawcurve
File "Sop/groupbylasso, ViewerStateModule", line 5, in <module>
File "Sop/groupbylasso, opdef:/Sop/groupbylasso?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/groupbylasso?Sop/groupbylasso
File "Sop/rbdpaint, ViewerStateModule", line 6, in <module>
File "Sop/rbdpaint, opdef:/Sop/rbdpaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/rbdpaint?Sop/rbdpaint
File "Sop/shotsculpt, ViewerStateModule", line 13, in <module>
File "Sop/shotsculpt, opdef:/Sop/shotsculpt?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/shotsculpt?Sop/shotsculpt
File "Sop/vellumbrush, ViewerStateModule", line 8, in <module>
File "Sop/vellumbrush, opdef:/Sop/vellumbrush?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/vellumbrush?Sop/vellumbrush
File "Sop/fibergroom, ViewerStateModule", line 10, in <module>
File "Sop/fibergroom, opdef:/Sop/fibergroom?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/fibergroom?Sop/fibergroom
File "Sop/frankenmusclepaint, ViewerStateModule", line 6, in <module>
File "Sop/frankenmusclepaint, opdef:/Sop/frankenmusclepaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/frankenmusclepaint?Sop/frankenmusclepaint
File "Lop/followpathconstraint, ViewerStateModule", line 11, in <module>
ModuleNotFoundError: No module named 'sidefx_curve'
File "Lop/followpathconstraint, opdef:/Lop/followpathconstraint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Lop/followpathconstraint?Lop/followpathconstraint
File "kinefx::Sop/adapttoterrain, ViewerStateModule", line 3, in <module>
ModuleNotFoundError: No module named 'kinefx'
File "kinefx::Sop/adapttoterrain, opdef:/kinefx::Sop/adapttoterrain?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/kinefx::Sop/adapttoterrain?kinefx::Sop/adapttoterrain
File "labs::Lop/karma::2.0, ViewerStateModule", line 18, in <module>
ModuleNotFoundError: No module named 'ParseExrMetadata'
File "labs::Lop/karma::2.0, opdef:/labs::Lop/karma::2.0?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/labs::Lop/karma::2.0?labs::Lop/karma::2.0
File "labs::Sop/wfc_sample_paint, ViewerStateModule", line 6, in <module>
File "labs::Sop/wfc_sample_paint, opdef:/labs::Sop/wfc_sample_paint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/labs::Sop/wfc_sample_paint?labs::Sop/wfc_sample_paint
