Mac M3 Houdini installation Mops does not work
   1044   1   0
I followed the prompts and copied the MOPS.json file to Houdini XX/packges/
This is my json file content:
	"env": [
			"MOPS": "/Users/hendasheng/Documents/HoudiniPackges/MOPS/"
            "HOUDINI_PYTHONWARNINGS": "ignore"
	"path": "$MOPS"
https://github.com/user-attachments/assets/138d1d1d-1d7c-4fb1-b0c7-7e2915e10f01 [github.com]
But I still can't access Mops in Houdini, is there something wrong with my steps?
Thank you very much for your help!
I tried it myself and the problem was solved. It was my folder path that was wrong.
If you don't understand the description of "Mac OS: ~/Preferences/Houdini/XX.X/" in the document, just enter "~/Library/Preferences/houdini" in "Finder -> Go to folder".
You will see the Houdini version folder.
Then, follow the instructions in the document to create a packages folder and set up a json file.
After restarting Houdini, you can see MOPs Tools.
I hope this helps Mac users who are confused about this.
