I have tried over and over to load wavefront .obj files. The geometry loads fine, but there are never any materials. Other (including cheepo) 3d programs load the same .obj file just fine, including materials. What am I doing wrong. I am using the file menu for imorting geometry.
No materials with .obj import
6002 4 3- primeuser
- 3 posts
- probbins
- 1145 posts
- symek
- 1390 posts
primeuser
I don't think Houdini supports OBJ materials, does it? If this is a problem for you, maybe you can try fbx import, much more advanced materials are supported by that standard anyway. Mtl holds just a few basic settings.
sy.
- rofthorax
- 38 posts
primeuser
Are these Maya Obj files?
If Obj files hasn't changed since Wavefront TAV,
there should be some “.mtl” files somewhere.. The materials
are called by name in the OBJ files and partitions on the
surface groups.
I've been out of it for a long time, but this might help..
I donated the DEC Alpha Ton made his first 64-bit port of blender to.
Okay if I survive, SideFX has to be pretty cool. Otherwise this is a totalitarian regime.
- AnimGraphLab
- 66 posts
Bumping this aged thread for future generations...
Thanks to SideFX Labs, there's a Labs OBJ Importer [www.sidefx.com] which loads MTL file also.
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
