KineFX/APEX Example of Bones Animating Along A Curve Request
1623 6 3- syntheticperson
- 170 posts
hello.
I'm learning how to rig a porpoise using KineFX/APEX.
I want to rig it so that the body follows a curve in the shape of a sine wave, to mimic the porpoise "porpoising" repeatedly in and out of the water.
Here is video reference of the swimming behavior I want to mimic:
https://youtu.be/Y6SFPsRfSRA?si=w0rYgXskxCe37B6C [youtu.be]
I found this ancient Houdini snake rig tutorial that shows the functionality I'm looking for.
https://youtu.be/Eo6Lue1TMZU?si=-EILM4iKgUK5zkim [youtu.be]
Can someone point me to an example of how to do this in KineFX/APEX? 🙏🏽
Edited by syntheticperson - 2024年9月4日 23:52:57
- PHENOMDESIGN
- 172 posts
The content library might cover your needs:
https://www.sidefx.com/contentlibrary/character-switching/ [www.sidefx.com]
https://www.sidefx.com/contentlibrary/elephant-trunk-sine-wave/ [www.sidefx.com]
https://www.sidefx.com/contentlibrary/kinefxapex-workflow/ [www.sidefx.com]
https://www.sidefx.com/contentlibrary/elephant-seal-fem/ [www.sidefx.com]
Edited by PHENOMDESIGN - 2024年9月8日 21:50:23
PHENOM(enological) DESIGN;
Experimental phenomenology (study of experience) is a category of philosophy evidencing intentional variations of subjective human experiencing where both the independent and dependent variable are phenomenological. Lundh 2020
- syntheticperson
- 170 posts
PHENOMDESIGN
Hi PHENOMDESIGN, thanks for the suggested examples. I'll check them out.
Edited by syntheticperson - 2024年9月9日 00:46:20
- edward
- 7899 posts
- syntheticperson
- 170 posts
edwardThanks, Edward.
For something like the snake, you can also try using the rig::CurveConstraint node that allows you to create transforms constrained to a curve at a particular u value.
However, the documentation for the APEX curve constraint is sparse:
http://127.0.0.1:48626/nodes/apex/rig--CurveConstraint [127.0.0.1]
It would be helpful if someone could point me to an example of the usage of this function.
The other challenge is that I would need to constrain each joint along the spine of the porpoise to the curve.
This means I would need to calculate the distance along the curve as a U value based on the distance between the joints along the porpoise's spine.
Does anyone have any examples of how to do that?
- william_harley
- 70 posts
- syntheticperson
- 170 posts
