I installed Houdini20.5..332 on Rocky Linux 9.4 and when I try to start hkey from the terminal, it starts but I get the following warning: "License server is not running".
I have already installed the Linux packages described in the following page, but the warning still appears.
Linux package requirements for Houdini 20.5 [www.sidefx.com]
Qt for X11 Requirements [doc.qt.io]
Got error when I lunch hkey from terminal on Rocky Linux9.4
743 3 1-
- Shigeru Iriki
- 22 posts
- alexwheezy
- 319 posts
- Shigeru Iriki
- 22 posts
alexwheezy
I think you don't have the appropriate service running.Also when installing the software and the licence server, Houdini had to create the directorysudo systemctl status sesinetd.service/usr/lib/sesi
Thanks for your reply.
I recall that I once experienced a similar problem to the link below when using Houdini 19.5 on Rocky Linux 9.3.
https://www.reddit.com/r/Houdini/comments/y2p8dv/houdini_195_license_server_problem_on_linux/?rdt=61930 [www.reddit.com]
At that time, Houdini did not support Rocky Linux yet, but I found that Houdini 20.5 supports Rocky Linux, so I am in the process of trying it out.
- Shigeru Iriki
- 22 posts
Almost solved..
I executed the following command
sudo systemctl enable sesinetd.service
sudo systemctl daemon-reload
sudo systemctl start sesinetd.service
Now I can run hkey, but even after installing the license, I get a DIAGNOSTIC message "Could not open the license file", so I have to give access to the license file, and Houdini 20.5 will now run on Rocky Linux 9.4.
