Hi there.
I was running Houdini Engine 5.0(API:7) on 3ds Max 2023 with Houdini FX 19.5.368, and I attached the simple HDA showed in the
the following pic as a modifier, then 3ds Max just kept crashing when I was changing face selection. All infomation I got is "Invalid argument given: No data found." from Max's log.
If anyone have any ideas please let me know. Thanks.
3956 2 2- VitaminC
- 4 posts
- VitaminC
- 4 posts
- Miszla
Reviving this topic: I've been trying to make some HDA's for 3DS Max and I'm getting the same error and a crash. I noticed that it occurs after I put some nodes into the network: like Polyreduce or Labs Dissolve Flat Edges. It also doesn't always occur, only on some meshes, but I can't identify what is different about the ones that don't work. Did anybody have any luck in identifying the cause of this? It's hard to make a LOD tool without using Polyreduce node...
Houdini Version: 19.5.493
Houdini Engine: 5.0 (API: 5)
Edited by Miszla - 2024年10月30日 06:53:56
