Houdini 19.5.682起動時にクラッシュする
   505   2   0
Houdiniをインストールした直後は問題なく起動できていたのですが、数日経って起動しようとすると下記エラーが発生して起動できなくなりました。
一度アンインストールし、再度インストールし直した時も、始めは起動が出来るのですが、間を空けると同様のエラーが発生して起動できなくなります。
Error running event handler:
File "Sop/heightfield_drawmask, ViewerStateModule", line 4, in <module>
File "C:\Program Files\Side Effects Software\Houdini 19.5.682\python39\lib\site-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'sidefx_stroke'
File "Sop/heightfield_drawmask, opdef:/Sop/heightfield_drawmask?ViewerStateInstall", line 1, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.682/houdini/python3.9libs\viewerstate\utils.py", line 969, in register_pystate_embedded
raise ViewerStateException("createViewerStateTemplate not found in {}".format(node_type.sourcePath()))
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/heightfield_drawmask?Sop/heightfield_drawmask
File "Sop/heightfield_paint, ViewerStateModule", line 8, in <module>
File "Sop/heightfield_paint, opdef:/Sop/heightfield_paint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/heightfield_paint?Sop/heightfield_paint
File "Sop/attribpaint, ViewerStateModule", line 6, in <module>
File "Sop/attribpaint, opdef:/Sop/attribpaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/attribpaint?Sop/attribpaint
File "Sop/groupbylasso, ViewerStateModule", line 5, in <module>
File "Sop/groupbylasso, opdef:/Sop/groupbylasso?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/groupbylasso?Sop/groupbylasso
File "Sop/rbdpaint, ViewerStateModule", line 6, in <module>
File "Sop/rbdpaint, opdef:/Sop/rbdpaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/rbdpaint?Sop/rbdpaint
File "Sop/shotsculpt, ViewerStateModule", line 13, in <module>
File "Sop/shotsculpt, opdef:/Sop/shotsculpt?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/shotsculpt?Sop/shotsculpt
File "Sop/vellumbrush, ViewerStateModule", line 9, in <module>
File "Sop/vellumbrush, opdef:/Sop/vellumbrush?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/vellumbrush?Sop/vellumbrush
File "Sop/fibergroom, ViewerStateModule", line 10, in <module>
File "Sop/fibergroom, opdef:/Sop/fibergroom?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/fibergroom?Sop/fibergroom
File "kinefx::Sop/adapttoterrain, ViewerStateModule", line 3, in <module>
ModuleNotFoundError: No module named 'kinefx'
File "kinefx::Sop/adapttoterrain, opdef:/kinefx::Sop/adapttoterrain?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/kinefx::Sop/adapttoterrain?kinefx::Sop/adapttoterrain
2024-11-08 09_33_58-Window.png (17.1 KB)
My Documents 以下にある houdini19.5 というディレクトリを別名にして Houdini を再度起動してみて下さい。
これで起動できれば、初期設定ファイルの中に何かエラーがあるということになります。
起動できたら、 こちらの要領で診断情報を出力してみてください。
https://www.sidefx.com/ja/faq/question/444/ [www.sidefx.com]
再び問題がありましたら、このマシン情報を info-jp@sidefx.com に送ってください。
取り急ぎ宜しくお願い致します。
返答ありがとうございます。
提案していただいた方法を試してみましたが同じエラーが発生し、再起動をしても改善されないのでどうしたものかと悩んでおりましたが
数日経った今日改めてHoudini19.5を起動すると問題なく起動出来るようになっていました。
依然根本の原因は不明ですが一先ずこのまま使用していきたいと思います。
お騒がせして申し訳ありません、ご対応ありがとうございました!
