Copy Parameter From Active Node On A Switch
   208   1   0
Trying to drive the scale of an object based on the divisions of a grid. Super easy with one source grid, just copy parameter > paste relative reference, etc.
Currently working on a project that requires a lot of different scale variations so I have quite a few source grids. Currently have them all setup going into a switch.
Is it possible to copy a parameter from the active node on a switch? So that I can just change the input and it automatically references the grid divisions of the selected node upstream?
Hi you can use this py expression for your target grid (hip below):
switch_path = '/obj/geo1/switch1'
switch = hou.node(switch_path)
switch_id = switch.parm('input').eval()
grid = switch.input(switch_id)
return grid.parm('rows').eval()
# return grid.parm('cols').eval() # for columns
grid_switch.hiplc (94.0 KB)
