Issue with camera import from Houdini to Touch Designer
   304   1   0
We need to export a camera that has been made in Houdini to Touch Designer. However when exporting it as an Alembic, the animation of the camera works but it's not possible to get back the rotate informations since the animation curves gets merged with the Translate curves.
When trying to export in USD, and import it to Touch Designer, it gets suddenly very laggy and it's not possible to work efficiently anymore.
Is there a workflow we could try ?
Thank you
You can import the camera data into Chops in Houdini and export a .chan file. This can be imported into Touchdesigner that you can use like any other channel data.
