Custom volume AOVs in karma
   99   1   1
Hello. I was wondering how could I do different aovs for volumes like an height mask with or a mask based on a noise with karma, etc...
I have been trying by myself but I dont find the answer.
The short answer is that there is a karma aov node you can add to a karma material. It’ll feed any input in as a custom aov.
The long answer is that USD doesn’t support material based aovs. It generally expects either an LPE expression or a primvar. You can add custom aovs using either by using the additional render vars node.
The karma aov node that sidefx built to get around this limitation in the usd specs.
madebygeoff.com
