Mix node not working as expected?
287 1 0- agentdoug456
Hey guys, when I switch between using a mltx tiled image and a hextiled image (using the same image file) in the bg input of the mix node, the result on the bottle changes. When using the tiled image node it works the way I expect, mixing the two textures together, but when I plug in the hextiled texture it get's all washed out. Not sure why this is happening.
- GustavBP
- 3 posts
