ODTools for Houdini
30679 45 11- LukeP
- 374 posts
- Mike_A
- 286 posts
- luis_santos
Hi, I am trying to batch convert mantra materials of kitbash models to materialx , I am using houdini 20.0 but the tool casts this error:
Error creating mtlx file: The attempted operation failed.
Invalid node type name for Node: /obj/KB3D_CyberPunk/matnet/KB3D_CBP_AtlasDetails
Node not supported: global
Node not supported: output
Node not supported: collect
Node not supported: computelighting::2.0
Node not supported: bind
I wonder if this functionality works only for houdini 19?
or if I am doing something wrong
Thank you in advance!
- Jip
- 19 posts
Hi all,
I've just installed OD Houdini shelf tools for houdini 20.5.410 win11.
I put ODHoudiniShelfTools2021 in C:\Program Files\Side Effects Software\Houdini 20.5.410\Plugins\
I can add any python panels to desktop but 2 : "OD asset library" and "OD snapshotManager".
"OD asset library" gives me this error message :
There is an error in the OD Asset Library script.
File "<stdin>", line 1, in <module>
File "C:/Program Files/Side Effects Software/Houdini 20.5.410/Plugins/ODHoudiniShelfTools2021/python_panels/assetLibrary.pypanel", line 3, in createInterface
<!-- This file contains definitions of Python interfaces and the
File ".\assetLibrary.py", line 10207, in __init__
File ".\assetLibrary.py", line 9147, in readDirectories
PermissionError: Permission denied: 'C:/Program Files/Side Effects Software/Houdini 20.5.410/Plugins/ODHoudiniShelfTools2021/python_panels\\assetLibraryDirectories.json'
"OD snapshotManager" gives me this message :
There is an error in the OD snapshotManager script.
File "C:/Program Files/Side Effects Software/Houdini 20.5.410/Plugins/ODHoudiniShelfTools2021/python_panels/snapshotManager.pypanel", line 4, in onCreateInterface
interfaces menu. It should not be hand-edited when it is being
File ".\snapshotManager.py", line 1374, in start
File ".\snapshotManager.py", line 1026, in refresh
PermissionError: Permission denied: 'C:/Program Files/Side Effects Software/Houdini 20.5.410/Plugins/ODHoudiniShelfTools2021/python_panels\\snapshotManagerPrefs.json'
So it seems there is maybe some permission problem.
Any solution to make them work ?
Thanx.
Thanx.
Edited by Jip - 2024年12月7日 17:02:12
Senior 3d artist - many 3d softwares.
- oliver7
- 285 posts
Jip
Hi all,
Thanx.
that is not where you should install ODTools. you should NEVER put your 3rd party tools into the sidefx program files folder. Please read the installation instructions again. https://www.notion.so/odtools/Installation-Update-1c040264a79e46799e5617be99587ef0 [www.notion.so]
Oliver Hotz
Origami Digital
Author of ODTools for Houdini: https://origamidigital.com/cart/index.php?route=product/product&path=59_63&product_id=66 [origamidigital.com]
Origami Digital
- Jip
- 19 posts
oliver7
I read it before installing and saw :
1 Simply unzip the folder into a folder of your choice.
Typically I make a folder called: ODHoudiniShelfTools2021 and copy it into the houdini documents folder.
If you are choosing to put the tools into a different location, modify the paths in the .json file.
This is what I did (modify the path in the .json file). But I will change the location. Better than doing wrong thing with permissions.
Thanx.
Edited by Jip - 2024年12月8日 06:51:45
