I’ve been struggling to eliminate some stuttering issues in my volume.
Currently, I’m using the retime node and have tried different volume blending Modes, but the problem persists.
Does anyone have any ideas or suggestions on how to fix this?
Volume Retime Stuttering
546 8 2- Wouter Lichtenbelt
- 4 posts
- Tanto
- 463 posts
- 4 posts
Tanto
One tip is to never have a mix of blended and unblended frames, so make sure your retime coefficient never results in integer frames from the original sequence.
I have already given that a go in the results above, where the retime frames would never land on frames like 1001, 1002, etc. Unfortunately, that hasn't fixed the problem.
- 8836 posts
Your best bet would be to use Advected mode and making sure you have correct vel volume present in your cache
By correct I mean that it represents velocity per second at the current FPS
For example things like simming with timescale other than 1 would produce incompatible vel for retiming ao that would need to be reflected in the settings by scaling it accordingly for advection purposes
Edited by tamte - 2024年12月20日 06:51:03
- 4 posts
tamte
By using a timescale on my sim, would there still be a way to get the correct velocity out? Or would there be no other option than to set the timescale to 1?
- Tanto
- 463 posts
- 8836 posts
- 4 posts
- 8836 posts
Wouter LichtenbeltBecause vel is in seconds, timescale affects just advection speed
That seems to have done the trick. Thanks!
Is there a reason why the velocity field is not affected by the timescale in the solver? I was expecting it to be?
This makes it much easier for all the velocity shaping tools to work the same way rather than having to account for timescale
Also in real life the velocity of the object doesnt change if you observe it with higher fps camera
It's however important to be aware of this as you may want to adjust vel for the purpose of MB or as in your case retiming
