How to drive parameter with point attributes
   Views 3784   Replies 4   Subscribers 3
Hi, I'm very new to Houdini and I have a question.
I want to use @Cd.r attribute value to drive the height of the mountain node. I did try using attribute promote to change the attribute type to detail, but on the spreadsheet it seems it's not transferring datas of all individual points.
I also tried using point(0, 0, “Cd”, 0) in height parameter, but because of second 0, it just seems its only getting the @Cd.r value of the point number 0.
I want individual points to have different height value(same as @Cd.r value) on the mountain node.
How do I do this?
Screen Shot 2019-10-13 at 10.58.50 PM.png (1.5 MB)
You cannot do that. The mountain node is an hda that wraps a regular attribute vop. The parameters cannot be driven by attribute values. (technically it can using point() expression but that would drive the height with just one point's value)
There's a couple ways to go about controlling the height with an attribute.
  1. Unlock and edit the mountain, adding a bound attribute to the attrib vop within that modifies the height being used.
  2. Use subsequent nodes to compute a delta value, and mix it back to the original using the attribute value.
  3. Use the attribute composite node.
it looks like, that you can also set a point (float) attribute, which is used by the mountain node as height mulitplier (for each point).
mountain_height.hipnc (121.3 KB)
I’m running into several tutorials pointing out the Mountain SOP height can be controlled by painting a "height" attribute. And when I download this example scene it works but seems to use an old Mountain SOP.
I tried this in 20.5 and this no longer seems to work with the new Mountain SOP.
"Height" was changed to "Amplitude" and is controlled by a “amplitude" attribute, but no matter what I try, when I paint an "amplitude" attribute nothing happens. Even not when I try to manually reference the painted attribute in the Amplitude channel.
Anyone know how to control the Mountain or Peak SOP with a painted attribute ?
Thanks.
Just figured it now is controlled by the "blend attribute".
Even better.
