Subtract Constant VEX node
   3318   2   1
? am I going blind ? I :shock: :roll:
Not sure where to find this node as I dont see it here for adding to my network short of copying and pasting from an 8.XX file where do I find?
Im sure Im missing the obvious. I did a search didnt find anything..
I haven't seen that node in any of the 9.x builds. I suspect since it was redundant it was removed in order to try and keep the list of nodes smaller. You can always just use a Add Constant node and use a negative number as the constant.
Wolfwood
Interesting Woolfwood. Cool thanks.
For the sake of organization it still “looks nice” to have the subtract constant as well as the add at a glance. In the case of redundancy why not then just have a single “math_constant” node with a switch inside that allows the user to chose between ‘ add, subtract,multiply or divide’
but anyway . hehehe.
Thanks a lot!
:idea:
