I have seen a couple of topics regarding this problem but couldn't solve it yet. Here is the terminal output, anyone has a solution for this ?
Last login: Fri Feb 19 01:16:18 on ttys000
cd /Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources;source houdini_setup
Mert-Yamaks-MacBook-Pro:~ Mert$ cd /Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources;source houdini_setup
The Houdini 10.0.528 environment has been initialized.
Mert-Yamaks-MacBook-Pro:Resources Mert$ Houdini
Mert-Yamaks-MacBook-Pro:Resources Mert$ 2010-02-19 01:19:06.043 houdini invalid drawable
2010-02-19 01:19:06.049 houdini invalid drawable
2010-02-19 01:19:06.052 houdini invalid drawable
2010-02-19 01:19:06.057 houdini invalid drawable
dyld: Library not loaded: /usr/X11R6/lib/libSM.6.dylib
Referenced from: /Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/hsvg/hsvg-real
Reason: image not found
Houdini has no icons in Snow Leopard
3940 1 1-
- mertyamak
- 50 posts
- MikeTaylor
- 154 posts
mertyamak
Houdini requires X11 to be installed on your Mac. X11 is available from Apple, or on your OS X install DVD. Houdini itself does not use X11, but a helper program that we use to generate our icons does. We hope to eliminate that dependency in the future.
I hope that helps!
