simple question:
i tried to change $JOB by putting JOB var in window environment variables (control panel), but i didn't work. So ,how to change/control this var?
thx,
clay~
how to set $JOB
16862 8 1-
- clay
- 58 posts
- edward
- 7934 posts
- deecue
- 412 posts
- clay
- 58 posts
- deecue
- 412 posts
are you seeing if it works in an already created file or in a new one?
cause if it was created a while back, JOB could have gotten saved to a different location in your global variables.. go to settings->aliases and variables.. under the variables page there should be a job variable with a value for your location it's representing..
but it should work fine for a new file…
did you try a different location just for kicks?
Dave Quirus
- clay
- 58 posts
i see what u mean,
that ‘created file and new file’ gave me the idea.
the problem is : my houdini icon is not a link to the app itself but (i changed it before) it points to my : template001.hipnc
so i didn't realize that i always open template001.hipnc file everytime i double click my houdini icon (i already forgot about it), i was thinking that i just started houdini and start new file.
so since i open this hipnc file, the $JOB is already set. that's why the changes i just made has no effect.
thanx a lot, deecue.
anyway i changed this link because i set that template001.hipnc to a specific UI configuration, and i want to use this config everytime i start houdini.so i open this file and later i save as different name.
in this file, I make same changes like putting very small size background file in my network editor (network editor display option ), so i can change color independently - different from general background color. The problem i don't know how to make this changes permanent.
does anyone know how to save it as default? in viewer display option, there's a button labeled ‘ save as default’ but in network editor display option, this button just doesn't exist.
thanx,
clay~
thanx,
clay~
- Stremik
- 170 posts
- edward
- 7934 posts
- clay
- 58 posts
