Houdini fatal errors for H11.0.504 & H11.0.528
   6164   5   1
If anyone can give advice, I would greatly appreciate it.
synopsis below:
OS: 10.5.8
2.2 ghz intel core 2 duo
graphics card: GeForce 8600M GT
4 gb ram
I was running Houdini 10.0.295 apprentice HD on my system - worked fine.
Then, upgraded to H11 11.0.504 (apprentice HD). Before I updated, I redeemed the
license. I installed 11.0.504 and it ran fine.
Yesterday, tried to open 11.0.504 and I got fatal error.
Downloaded the 11.0.528 version and installed it and same thing: fatal error.
If I open License Administrator for either 11.0.504 or 11.0.528, both have the 3 green check marks:
license server is running; license server is allowed to serve license; license admin can read and modify local licenses
10.0.295 opens and runs, but the 2 H11 versions give me a fatal error.
Any advice would be greatly appreciated.
thanks!
Glen
I had problems on my mac book pro with h11. In the end I just uninstalled all versions and cleaned house. Installed a fresh copy including fresh user directory. Since then I have not had many problems
rob
Gone fishing
thanks rob!
i will uninstall. did you uninstall H10 too. or just H11?
lastly, fresh user directory - if you don't mind - how does one do that?
greatly appreciate the response. thnx!
I suspect I a having the same issue… however this is a relatively brand new machine and I've only installed H11 on it and both times I get a UI with white squares where the icons should be.
Basically, it's telling me it can't find "/tmp/tools_***.png which I'm assuming is where the icons should be?!
Any ideas?
Screen shot 2010-10-15 at 2.10.22 PM.png (166.0 KB)
If I would have read further down I would have found this:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=20312 [sidefx.com]
Which handled my problem. ops:
thanks rob,
reinstalled and created a new directory. worked beautifully
thanks!
- glen
