voronoi forEach export .obj?
   Views 4995   Replies 4   Subscribers 0
I need to export all the pieces that are created by a ‘voronoifracture’ node and was wondering if there was a straightforward way to do this?
Can I use a ‘forEach’ node to do this?
cheers
fred
Hey Fred,
if all the pieces are in a separate groups you can use the foreach for that. Either select the by group or by value, put a delete sop in the foreach and delete everything but the current piece(in case of the by value option) and then pipe that in a file sop or rop geometry.
No need to use a foreach (which can be very slow if you have lots of pieces). Just pipe your voronoi tool into a delete sop and use the following expression in the group field:
myVoronoiGroup_`$F`
Set the operation to delete non-selected and plug it into a rop.
myVoronoiGroup_`$F`
Thanks a lot for the tips!
I'll try these methods.
cheers
fred
